Thread: Coolant light flickering
Results 1 to 8 of 8
  1. #1 Coolant light flickering
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    So My low coolant light was on for forever and I finally got around to replacing the sensor. I put a brand new sensor in, I topped off the coolant in the radiator and everything was fine for about 5 minutes. I drove around and the low coolant light would come on every once in a while. Usually under braking or going over bumps. I popped the cap off the radiator and it was full but the light came on for a bit even while I was looking right at the full radiator. Is there something Im missing here?
  2. #2 Re: Coolant light flickering
    St. Louis
    Did you bleed the cooling system after installing the new sensor? Might have some air trapped in the system tripping the light occasionally.
  3. #3 Re: Coolant light flickering
    Nov 2009
    Orlando
    Im not really too sure about the coolant fill procedure and if what I did counts as bleeding it. What I did was I ran it for a few minutes till it was warm and opened the little valve on top of the thermostat housing till a small stream of coolant was coming out. There werent any bubbles it was a continuous stream and the coolant was to the brim of the radiator. (The cap was off so I could see it. I tried it with the heater on and off. Kept the coolant topped off in the radiator while the little valve had a stream running out. Anything else I need to do?
  4. #4 Re: Coolant light flickering
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Is there a good connection? Did the terminal click into place? Check the wiring to see if it's good.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  5. #5 Re: Coolant light flickering
    St. Louis
    Nope. Sounds like you got it bled out just fine! Might just be electrical. Maybe check the harness and see if its rubbed through anywhere grounding out?
  6. #6 Re: Coolant light flickering
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    x3 on wiring
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  7. #7 Re: Coolant light flickering
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    clean the sensor, and flush your system
    <MiZzBeCcA>its not rape if you yell suprise
  8. #8 Re: Coolant light flickering
    St. Louis
    I'd bet its still pretty clean
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Low coolant light?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2009, 01:13 PM
  4. Low Coolant Light
    By Helios in forum General Tech Discussion
    Last Post: 02-19-2009, 04:13 PM
  5. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
