Thread: reusable engine parts
Results 1 to 7 of 7
  1. #1 reusable engine parts
    Central Florida
    i know that the cam, crank, main bolts all need to be replaced along with gaskets on a rebuild but what all is reusable? like timing chain, lifters, connecting rod bolts, flexplate bolts and whatever else anyone can think of.
    im in the middle of a budget rebuild and kinda need to get it back road worthy sooner and cheaper than later and more expensive.
    thanks in advance!
    1998 Pontiac GTP - rebuilding
    1991 Mazda MX6 GT - DD
  2. #2 Re: reusable engine parts
    you can re-use a cam and crank, just get them machined.
  3. #3 Re: reusable engine parts
    things that automatically get changed.
    Bearings (after checking them)
    Bolts (every bolt is TTY)
    Timing chain (it's cheap, don't put a semi stretched one back in)
    Something to keep in mind though is usually you can get a used motor cheaper than you can rebuild. And if you are turboing.. look into the 04+ GP NA motor. I've seem them low..like $300 for a motor with 50K
  4. #4 Re: reusable engine parts
    Central Florida
    i couldn't really find anything used around me at the time and already had the machine work done.
    so im going to need all new bolts. it there a way to clean the lifters?
  5. #5 Re: reusable engine parts
    St. Louis
    Quote Originally Posted by turbo6 View Post
    Did you have the block line bored as well? I've heard that this is a must when rebuilding one of these motors.
  6. #6 Re: reusable engine parts
    Central Florida
    not that i remembered but everything was spec. out and measured, and the guy has been doing it for years on end.
  7. #7 Re: reusable engine parts
    Florida
    I cleaned mine out by soaking them in parts cleaner, then letting them dry off, and then soaking them in oil before I reinstalled.
  1. l32 aluminum blower gasket reusable?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 01:39 AM
