Thread: pulley question
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: pulley question
    tell me why you'd want a 180* thermostat. because you want to lose MPG? because you want to put extra wear on the motor? because the car is faster or has less knock with it (it really doesn't, for real)?
    its a useless mod that the old school guys had to do because they had no way of tuning for their mods so they had to do things like run colder thermostats, really cold spark plugs, scale MAF frequencies, and run high octane in order to run fast. its old technology and in the modern car world its' really lost its place.
    I'm gonna play the devils advocate on your post for a second...
    I see your point...but considering the technology in these motors...they are old school compared to other things released that the time...so, a colder temp t-stat, colder plugs, etc. DO HELP...but you must be modded to capitalize on the effects. So, your saying that since I'm modded I'd be better off running a 195* and AL606's?
    See what I'm getting at? I agree 110% though on the fact of putting a t-stat and colder plugs in a car that is stock pullied or close to stock is a waste of time and money.
  2. #22 Re: pulley question
    Never Never Land
    so when do you start actually benefiting from a thermo and plugs? 3.4? 3.2?
  3. #23 Re: pulley question
    plugs, yes. thermostat, no.
    plugs will always help with more boost, but running the motor cooler does nothing for ya.
  4. #24 Re: pulley question
    Never Never Land
    so verdict is, plugs yes, thermo no...but my pulley size question...when do you actually start benefiting from them.
  5. #25 Re: pulley question
    Bastard Reptile's Avatar
    Kansas City, MO
    Considering the fact I know there are fueling and timing tables that directly relate from temperature, I'll roll with most of what you said. Unless you've got a tuner and ways to make the PCM happy with the temps you're running, it really doesn't do anything for you....might have 5 years or so ago though.
    IMO, drilled T-Stats are only good for one thing, and that's bleeding the coolant system 10X's faster than with a regular one, and even at that, some newer T-Stats have a check ball that opens when there's air in the system, and closes when the air is gone.
  6. #26 Re: pulley question
    Kansas City, MO
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    When you have the supports for a pulley/PCM combo, the benefits are as soon as the fuel trims settle down after changing it all around.
  7. #27 Re: pulley question
    GTX Level Member real diehl's Avatar
    Salina, KS
    Granny shifting not double clutching like you should...
    doesn't matter if you win by a foot or a mile
    signature removed for inappropriate content.
    -bio
  8. #28 Re: pulley question
    Never Never Land
    inch or a mile lol
  9. #29 Re: pulley question
    Minnesota
    Does it actually do more harm then good with a 180 tstat? I have one sitting here waiting to go in when I change all my gaskets and drop to my 3.4 but if stock one would be better im gonna go return this for teh stock 190
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  10. #30 Re: pulley question
    in all reality, yes. if youre driving the car all the time through all sorts of weather you should be sticking with the 195*.
  1. 3.4 Pulley Question
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2010, 09:32 AM
  2. S/C Pulley question
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:22 PM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. pulley question
    By novmadman in forum General Tech Discussion
    Last Post: 02-08-2009, 07:05 PM
  5. another pulley question
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:32 PM
