Thread: Premium fuel required!?
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41 Re: Premium fuel required!?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    What is the issue with ethanol fuel? Is it only a problem in SC cars? We have few stations (only one that I know) that sell 100% gasoline and not mixed with 10% ethanol.
  2. #42 Re: Premium fuel required!?
    Barksdale AFB, LA
    Ethanol has less energy per a given volume, so the car might not run as hard on an ethanol mix. I know that E10 drains about 3MPG on the highway on my car as opposed to running 100% gasoline.
    2009 Subaru Impreza WRX STI
  3. #43 Re: Premium fuel required!?
    May 2012
    Thunder Bay, Ontario, Canada
    So my 2007 Pontaic grand prix 3.8l supercharged should only run on premium? Ouch!
  4. #44 Re: Premium fuel required!?
    Ocala, FL
    Quote Originally Posted by 2007GrandPrixGT View Post
    Yes, as this 3 year old thread will teach you.
  5. #45 Re: Premium fuel required!?
    Out West
    Quote Originally Posted by Sabrewings View Post
    Actually, it leans out your fuel mixture a little, the car will correct for this in closed loop, but when running WOT you actually are running leaner than commanded.
    Whine with your Cheese?
  6. #46 Re: Premium fuel required!?
    Really?
    The owners manual and even the fuel door tell you what grade of fuel to run.
    Closed.
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  3. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  4. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  5. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
