Thread: New Waterpump, still no heat/running hot.
Results 1 to 4 of 4
Threaded View
  1. #1 New Waterpump, still no heat/running hot.
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Ok so I just put a brand new waterpump in my car. so far I've had to put about 3 gallons of antifreeze/water in my car. today its still running too hot ( not to the point where I need to pull over ) but above average, fans are screaming on high. it's still steaming from under the resivor jug and smell antifreeze. though I cannot find any leaks, I seem to have a bit more than average condensation coming from the exhaust still as well. I just did an oil change with this problem and seen NO trace of water in the oil so I dunno about head gasket...The air should have worked itself out of the lines by now as I've put atleast 50 miles on it since new waterpump...still seeing steam and smell burnt anti...
    Any suggestions guys? whose had this problem? it's an 06 w/ 92K
    No codes, don't see any leaks, no water in the oil, no oil in the water....
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. Corrosion on new timing sets? Plus advice on coolant elbows, LIM, AC, waterpump, etc
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 04:13 AM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. waterpump gasket
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 03-14-2010, 09:50 AM
  4. what does a bad waterpump sound like?
    By QwikGT in forum General Tech Discussion
    Last Post: 11-11-2008, 12:03 AM
