Thread: waterpump gasket
Results 1 to 9 of 9
  1. #1 waterpump gasket
    Donating Users blowfishRus6's Avatar
    g.a.
    is it common for it to go out???
    ive been trying to track down a coolent leak and though it was at the coolent elbows but now i dont think that is the case. its leaking over there somewhere, and it gets all over my cradle, but i cant find it. maybe the gasket is out on the water pump??? i put some radiator stop leak stuff in the radiator and the best i could i syliconed up the elbows but it still leaks.
    figured i would ask, what do yall think??
    p.s. the coolent elbows are new but the bottom one does not quite fit corectly. when i get it all into place it goes a little sideways. but i dont think its leaking.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: waterpump gasket
    g.a.
    nothing???
    well maybe someone knows what kind of bolts are holding the i guess powerstearing pulley on. i cant see it down there.
    its slow.
  3. #3 Re: waterpump gasket
    SE Level Member daveydavido's Avatar
    Feb 2010
    detroit
    that bottom elbow could be your problem, the oring might be broken
  4. #4 Re: waterpump gasket
    Jul 2008
    sumter,south carolina
    dude u seriously put stop leak in ur car? water pump on motor i bought was bad... theres a lil hole on pump... what purpose the hole is i dunno.... but thats where it was leaking from.
    02 GTP with mods 05 GP for DD
  5. #5 Re: waterpump gasket
    Jul 2008
    oh wow.... this thread is old as dirt.... way to bring back the dead. :|
  6. #6 Re: waterpump gasket
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    that hole is designed to leak coolant when the bearings start going bad. its doing its job. my cavalier had this "feature"
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: waterpump gasket
    Jul 2008
    learn something new everyday...
  8. #8 Re: waterpump gasket
    g.a.
    thats what that hole is for huh........... got this problem on another car.
    and yes this was fixed AWHILE ago
    and yes, radiator stop leak is some nasty gumming up stuff. never again.
    its slow.
  9. #9 Re: waterpump gasket
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by blowfishRus6 View Post
    x2 on that **** man, a leaky radiator is WAY easier to replace then a gummed up heater core
  1. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  2. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
  3. what does a bad waterpump sound like?
    By QwikGT in forum General Tech Discussion
    Last Post: 11-11-2008, 12:03 AM
  4. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
