Thread: ZZP Heads VS Intense Heads
Results 1 to 13 of 13
  1. #1 ZZP Heads VS Intense Heads
    Never Never Land
    Which would you guys say is better? I'm just curious. I like how intense has the flow chart on their website.
    Just wondering what your guys opinions are..especially those that have actually ran them on their car.
    I did a search but I didn't really get anything.
  2. #2 Re: ZZP Heads VS Intense Heads
    heads from a local engine shop > vendor heads
    youll pay 1/3 of the price and possibly get heads that perform better from a local shop that will port them for you. therefore, i choose none of the above. however, if i were to venture into it i bet they are nearly identical in how they perform compared to one another.
  3. #3 Re: ZZP Heads VS Intense Heads
    Never Never Land
    You know I ALWAYS thought about this shop that does heads. I drive by it EVERYDAY I work. I've always thought to myself that "they can't be much different than what ZZP/Intense do and they have to be a ton cheaper."
  4. #4 Re: ZZP Heads VS Intense Heads
    I get IS3/ZZPS3 Heads for more than half the price...if you want the info...shoot me a PM if your looking to get them done.
  5. #5 Re: ZZP Heads VS Intense Heads
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    ill consider this offer come this summer...lol
    2000 Daytona GTP(aka the slow fwd GTO)
  6. #6 Re: ZZP Heads VS Intense Heads
    Never Never Land
    is there much of a difference between stage 3 and 4?
  7. #7 Re: ZZP Heads VS Intense Heads
    Jan 1970
    Maquoketa, Iowa
    What do you need heads for or what are you running? Stock heads have made over 600whp on a turbo setup and over 360whp on xp cam s/c setups before. There's a point when cost per hp isn't there and heads can be considered at times one of them.
  8. #8 Re: ZZP Heads VS Intense Heads
    Never Never Land
    They'll be for the camaro.
    I just realized i put this in the Supercharged section...woops.
  9. #9 Re: ZZP Heads VS Intense Heads
    Never Never Land
    Do you mean more than half off of a little bit over half off?
  10. #10 Re: ZZP Heads VS Intense Heads
    Michigain
    Dirt Cheap Heads, Do it your self.. But be ready to spend hours and hour's doing so.. There's an amazing write up a freind of mine posted up on clubgp just how to do so and it's a sticky there.
    Cheap, Have them done local..
    Bang for the Buck, ZZP CNC'ed Heads.. Nice head for the money!
    High Dollar Heads, IMO ZZP cast head's own all.. But that's just my thought.
    Baller, Go pick up some Aluminum Heads..
    I've owned every set I've listed above besides the cast iron fully worked zzp heads. Dollar wise the CNC heads where the best bang for the buck, but I also put about 30 hours into a set of my own stock vavled ported heads that I feel flowed just as well if not better then the cnc heads. But I have no ture flow bench number's to prove that. I cant say much about the Aluminum Heads yet because I've yet to bolt them to my short block yet I've been around some Intense Heads and it left a bit to be desired IMO.. But to each their own. No matter what heads you put on the car it's going to be better then it was. Are heads suck it's just that simple. Even fully worked oversized vavle heads dont flow very well. But it's better then nothing.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
  11. #11 Re: ZZP Heads VS Intense Heads
    Never Never Land
    linky?
  12. #12 Re: ZZP Heads VS Intense Heads
    I mean I had mine fully done for about $700...fully assembled...only thing I didn't have done was get the bowls polished...and I did a little of that myself before they went on anyways...there are pics of them in my thread in the rides section if you click on my build.
  13. #13 Re: ZZP Heads VS Intense Heads
    I have a lot of pics of S3 heads if anyone wants to see what's done.
    Photobucket.com
    BillBost37
    rocket03
    Jasonparts is the subalbum I think.
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Heads
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-31-2009, 10:59 PM
