Thread: wont start
Results 21 to 40 of 45
  1. #21 Re: wont start
    GT Level Member Mitchstrp's Avatar
    Missouri
    Quote Originally Posted by Silver GTP View Post
    Is the vacuum line for the MAP sensor hooked up in the right place? I'm thinking that maybe you connected the vacuum line for the MAP sensor to the sensor above it and that line goes to the place the MAP sensor line is hooked up to.
    i have a wiring diagram and i have it ran correctly, besides it would still start not completely **** on me
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  2. #22 Re: wont start
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I don't think you get spark at all if the crank sensor is gone... or if it did you should have some really bad timing on the sparks if it didn't fire inline with the crank position and then make it misfire and backfire badly.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #23 Re: wont start
    Missouri
    my timing at WOT at the top of second gear was -4... this was thursday when i went WOT on my scan gauge.. i think the sensor was slowly crapping out on me..
  4. #24 Re: wont start
    SE Level Member fpgt17's Avatar
    Grand Rapids
    I am having the same problem and my car wont start! I am getting fuel and spark. Had coils and Icm tested... New Maf sensor as well. I was told try the Cps sensor now.... is that what yours ended up being?? I feel its my last and only option.. idk what else it could be?
  5. #25 Re: wont start
    Missouri
    pull the supercharger off and if there is coolant in the intake manifold or on the sc rotors then this is your problem. recently change any gaskets?
  6. #26 Re: wont start
    Grand Rapids
    Its just a GT even tho the top end swap will be coming soon... But no gaskets have been changed out recently. I have had people said Crank sensor or low pressure at the fuel rail/ bad pump or regulator. It keeps sending me in circles and i cant pinpoint this!
  7. #27 Re: wont start
    Missouri
    check the fuel pressure reg you can go to advanced and theyll rent you one. if the pressures fine your good. Crank sensors symptoms are no spark, wont turn over, and when it does start just shuts down.. you still have spark so thats not the case..
  8. #28 Re: wont start
    An even more common sign of the CPS failing is a bouncing tachometer while driving.
  9. #29 Re: wont start
    Missouri
    deez ^
  10. #30 Re: wont start
    Grand Rapids
    Well i tested the fuel pressure today at the rail.... I was onlu getting 10 PSI at key on acc! But my pump still sounds strong... So i then tryed to turn it over and watch to see if the pressure was any different. When i turned it over it then backfired and smoke came out from the back and front of the motor... Seems as if its off time and the exhaust valve was open instead of the intake. Even tho i didnt have much pressure at the fuel rail i feel like its the CPS... What do you guys think? Its getting too cold and i am limited on tools so this has gotta get figured out fast lol
  11. #31 Re: wont start
    Bastard Reptile's Avatar
    Kansas City, MO
    It almost sounds like both, but your fuel pressure should be at 50-55psi at least.
  12. #32 Re: wont start
    Grand Rapids
    i know its making me run in circles. I dont really wanna do the pump unless i have to. Is there a way to test the regulator and just rule that out too...????
  13. #33 Re: wont start
    Missouri
    test the reg.. take the vacuum fittin off while you try and start it and if gas shoots out its a bad reg.. thier 56 bucks at autozone. cps is a 30 min job for some people and other a 2 hr job IIRC. The sensor for that is only 28 bucks i believe. so start with the cheapest and if it doesnt help, go to the expensive. like reptile said your fuel pressure should be at 50-55 psi so your pressure is deffantly off.
  14. #34 Re: wont start
    Grand Rapids
    Thanks guys! i am bringing it home this weekend to tear into it... It will be nice to have my warm garage and TOOLS!
  15. #35 Re: wont start
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    Quote Originally Posted by Mitchstrp View Post
    good to know
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  16. #36 Re: wont start
    Missouri
  17. #37 Re: wont start
    Nov 2010
    Maryville, MO
    that is all
    // 2005 Comp G
  18. #38 Re: wont start
    Missouri
  19. #39 Re: wont start
    You guys are better on here than in real life
  20. #40 Re: wont start
    Missouri
  1. Car wont start help please.
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 09-07-2010, 10:23 PM
  2. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  3. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  4. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
