Thread: Strange vibration/rattle... 02GTP
Results 1 to 9 of 9
  1. #1 Re: Strange vibration/rattle... 02GTP
    Feb 2010
    Lincoln, Nebraska
    Quote Originally Posted by SlowNA06 View Post
    You Might be able to hold this off a bit with a little bit of stop leak but it will eventually need to be replaced.
    The fluid remains full and I haven't added but a *tiny* bit to it. It whines a lot, but ONLY when I turn left quickly while in motion. Adding fluid seems to have no effect on function. I haven't checked the fluid in probably 2 weeks now. The pump itself doesn't whine even when the wheel gets tough to turn at times. I can't really turn the wheel without bogging the engine when the car isn't moving, such as squeezing into a tight parking spot. The wheel will just plain stop turning if I try to steer while not moving. The power steering rack is wet at that plug thing. I would expect consistent whining of the pump if it were the pump because I've driven my share of cars with bad powersteering pumps and they whined all the time. Is the assumption correct?
    This shudder is your ABS system checking itself - should do that at 3-4mph after start then never again until next start. Perfectly normal.
    Interesting! I suspected the ABS system myself. Do certain cars do it more than others? It takes longer for it to check itself when I reverse. I know because I've tried it.
    Something is moving/shifting in the suspension... when you shift. Okay, enough wisecrack from me. Is this clunk a noise, jolt, vibration? Does it happen when you shift back to drive? Trans fluid full, pink, cool and froody?
    The "groan or clunk" has only occurred when I move the car immediately after first started when it's cold. It's more of a noise but I can definitely feel it. The car is already in gear and the "groan" is within literally 6 inches of moving. I definitely think it's the power steering since it occurs when I crank the wheel. It's not the transmission. My Tempo had a broken transmission/motor mount and talk about a clunk. The engine could literally move itself around... Going on a tangent there...
    BTW. Tranny fluid is pink and healthy. Power steering is a recent development. Cars these past 3 years have been dollaring and 50-cent piece-ing me to death.
  2. #2 Re: Strange vibration/rattle... 02GTP
    Pennsylvania
    Quote Originally Posted by shredaspud View Post
    I've had it kick in while reversing out of a spot and continue when I changed gears. It might be slower to check in reverse because you're going slower or braking.
  3. #3 Re: Strange vibration/rattle... 02GTP
    Feb 2010
    Lincoln, Nebraska
    I want to put it into neutral and see if it "checks" when I roll away. The strange things that I wonder.
  1. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  2. strange shaking
    By occrocks in forum General Tech Discussion
    Last Post: 12-18-2010, 01:19 PM
  3. 99 GTP Strange problems
    By msilverwood in forum General Tech Discussion
    Last Post: 11-14-2010, 07:18 PM
  4. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
  5. strange vibration from the front
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2009, 08:57 PM
