I finished my S1X and Gen V install and the idle is not holding steady. I still have stock idle settings. The idle will start to fall off a little bit and then jump up to stop from stalling. It will only drop to low 700's rpm range and then jump up to a little over 800. This will hold steady for a few seconds until it slowly drops off again. Is this a side effect of an S1X at stock idle settings or do I need to hunt down a problem? It runs great other than at idle.
