Thread: S1X idle setting
Results 1 to 7 of 7
  1. #1 S1X idle setting
    Donating Users
    South Deerfield, MA
    I finished my S1X and Gen V install and the idle is not holding steady. I still have stock idle settings. The idle will start to fall off a little bit and then jump up to stop from stalling. It will only drop to low 700's rpm range and then jump up to a little over 800. This will hold steady for a few seconds until it slowly drops off again. Is this a side effect of an S1X at stock idle settings or do I need to hunt down a problem? It runs great other than at idle.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: S1X idle setting
    Charles City, IA
    Thats what cams do. You can raise the idle a bit if you want to smooth it out.
    SMGPFC Two Nipple General
  3. #3 Re: S1X idle setting
    Donating Users
    South Deerfield, MA
    This isn't the lope that I would expect from a cam. It seems like it's about to stall when the idle bumps back up. This cycle happens about every 5 seconds. This is normal? If so, how much does the idle need to be bumped to hold stable? 50? 100?
  4. #4 Re: S1X idle setting
    Nov 2009
    Grand haven
    THAT IS WHAT CAMS DO. IF you dont like it raise the Idle to about 900-1050. Can we get an exhaust clip please?
  5. #5 Re: S1X idle setting
    Charles City, IA
    Set your idle at like 800.
  6. #6 Re: S1X idle setting
    Set your idle at 700...and love it.
  7. #7 Re: S1X idle setting
    Jersey
    you should raise that idle if you don't have a double roller
    16' wrx sti- stock
  1. Need advice setting my amp
    By Colossus in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2010, 01:54 AM
  2. setting up new system
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 11:27 PM
  3. Complaint With One Of This Forums Setting
    By Street Wolf in forum Forum Bugs/Suggestions
    Last Post: 12-22-2008, 01:29 PM
  4. Setting up account
    By PWNED in forum PCM Tuning
    Last Post: 08-23-2008, 06:29 AM
  5. Hood not setting right.
    By DanGTP in forum Visual/Body Modifications
    Last Post: 03-02-2008, 01:43 AM
