Should i go E85
Should i go E85
You should! BUT you better teach yourself how to tune and get some bigger injectors B/C with a higher compresson motor, cam, headers and pulley you WILL need larger injectors. might as well go with 65#ers.
If your not going e85 get some 39# ford mustang injectors (these are pretty cheap) too. they plug right into the 04+ harness and with our fuel pressure its almost the same as 42# injectors.
