Thread: Spark Plug tips gone!!! UPDATE 2/6/2011
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 112
  1. #81 Re: Spark Plug tips gone!!!
    SE Level Member ryan12473's Avatar
    Dec 2010
    Iowa, Burlington
    Quote Originally Posted by 01gpgt01 View Post
    Intake gasket might foul out a plug. Its not going to Lean a plug. Or melt a plug. Your rear cats probobly clogged, and yes theres a gasket for the exhaust manifolds
    And who runs plugs for 100K miles
    How would extra air fowl out a plug ? If each cylinder had its own o2 senser yeah but no.This car is stock with stock type ac delco plugs which easely go for 100,000 miles in stock trim. But thanks for the info on exhaust that helps my buddy told me it may not have manifold gasgets,was hoping for an easy fix.My car has 212,000 miles why would it ping and have a slight vibration when you slowly accelerate but if you hammer it it runs well not like the cats clogged.Does it have a steatched timing chain and have to much timing, burnt valve.I'v drove this car for ten years sence it had 21,000 miles on it and really like it I would hate to have to buy another gtp lol. Im disabled and cant do things like a few years ago otherwise id tear into it. Thanks for your thoughts on this.
  2. #82 Re: Spark Plug tips gone!!!
    it wouldnt be air that would be going into the cylinders if you had an intake gasket leak.
    it'd be coolant.
  3. #83 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    ok but how would that melt the wire on a sparkplug and why could'nt it be air. I'v never had a 3.8 apart.
  4. #84 Re: Spark Plug tips gone!!!
    The LIM gasket fails between the coolant jacket and the intake runner.
  5. #85 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    So whats my next step a compression check ,maybe a burnt valve?I hate winter!
  6. #86 Re: Spark Plug tips gone!!!
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by ryan12473 View Post
    did u **** up a plug or a wire?
    02 GTP with mods 05 GP for DD
  7. #87 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    Could be, to cold to check right now. That would be nice ,but I'm not that lucky,although it still runs hard.
  8. #88 Re: Spark Plug tips gone!!!
    Jul 2008
  9. #89 Re: Spark Plug tips gone!!!
    I just checked plugs in shorts.
    Its not too cold.
  10. #90 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    Its not too cold.
    Are the metal Lim gaskets available at autozone or who has the cheapest.
  11. #91 Re: Spark Plug tips gone!!!
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    No they dont, or At least not that i know of. GM dealer ship should have them you can get the whole kit from head gaskets, LIM gaskets, and Valve cover gaskets for like 120ish. You would need an upper intake gasket
    Just your normal 730whp 4dr family car.
  12. #92 Re: Spark Plug tips gone!!!
    Get the felpro permadry plus gaskets if you want aftermarket metal.
    prolly available at autozone.
    Just make sure its permadry plus.
    the package has a window so you can look at the gasket.
  13. #93 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    Cool thanks,thinking of finding a lower milage motor because mine needs timing chain, lim gaskets and upper ,exhaust man. gaskets and valve cover. I dont know if its worth all that with 213,000, whats ur opinion on this, and then I'd do all this to a used engine before install uhhh Help FEL-PRO Part # MS98014T PermaDryPlus®; Intake Manifold Gasket Set
    2nd Design; w/Rubber-plastic end seals w/Locating pins; Lower set int. manifold gskts. incl.
    $49.79
  14. #94 Re: Spark Plug tips gone!!!
    Dec 2010
    Iowa, Burlington
    There 75 plus tax at autozone or 50 pluse shipping at rockauto.com I'v used them a few times, there cheaper on most stuff if u can wait.
  15. #95 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    My engine build is a go!
    1. XP Cam
    2. Double timing chain
    3. 105# Springs
    4. 4340 input shaft
    5. 3.29 7/8in chain set
    6. Modified retainers
    7. New valve seals
    Not sure if im going E85 yet or not
  16. #96 Re: Spark Plug tips gone!!!
    Win.
    If you want a hook up on head porting...shoot me a PM.
  17. #97 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    Will I need mine ported?
    Win.
  18. #98 Re: Spark Plug tips gone!!!
    Jul 2008
    May as well while u got it apart. Porting is always good. If nick got the hookup on it. I'd go for it
  19. #99 Re: Spark Plug tips gone!!!
    ported heads = more flow.
    more flow = power.
  20. #100 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    Should i go E85
  1. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  2. Spark plug suggestions?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 08:43 AM
  3. New Spark Plug sugggestions
    By RichCresci in forum General Tech Discussion
    Last Post: 08-25-2008, 08:32 PM
  4. Spark plug issue?
    By TurboKent in forum General Tech Discussion
    Last Post: 04-12-2008, 03:07 PM
