Thread: Running rich
Results 1 to 9 of 9
  1. #1 Running rich
    Greenville, SC
    Car is running rich. Tons of black all over the back bumper. Would this be due to my BBV being blocked off ( recirc line capd)?
  2. #2 Re: Running rich
    why would you block the line on your BBV?
    also, none of us are going to be able to make a good guess unless you give us some data off a scanner. we will all just be pulling at straws and hoping.
  3. #3 Re: Running rich
    Pretty sure I thought he was Top Swapped...which in that case...I see why its blocked...
  4. #4 Re: Running rich
    you dont block the recirc line though, its still there...when you top swap you block the solenoids line so that it never sees boost/vacuum on the solenoid.
  5. #5 Re: Running rich
    No you take it off and leave it in a box.
    The top line sees vacuum and no boost and the bottom sees atmosphere.
  6. #6 Re: Running rich
    Greenville, SC
    its blocked due to me having no time to find the right vacuum line to connect it with.
    will this make it run rich as hell?
  7. #7 Re: Running rich
    5/64 or 5/32's forget which one.
    get that in washer fluid line and you're done.
    It depends if you leave the top or the bottom line off.
  8. #8 Re: Running rich
    Greenville, SC
    bottom of the BBV is capd. the bypass arm still moves.
  9. #9 Re: Running rich
    shouldnt have anything to do with your BBV, to answer your question.
  1. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  2. Rich vs Lean
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 05-23-2010, 11:39 AM
  3. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  4. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
