http://www.grandprixforums.net/side_gap.php
Aluminum - 2.65 Micro Ohms per centimeter
Gold - 2.24 Micro Ohms per centimeter
Copper - 1.67 Micro Ohms per centimeter
Silver - 1.58 Micro Ohms per centimeter
Platinum - 10.5 Micro Ohms per centimeter!
Iridium - 4.7 Micro Ohms per centimeter!
As you can see, the Iridium may last longer, but it's has more resistance to current. I wouldn't recommend the side gapping at the link I provided for you, but there's good information there. Also, the copper plugs will provide some amount of fail-safe before other parts of the engine break. Plus, it's good to see how the engine is running by checking the plugs a little more often than 100,000 miles. I bought the ngk Iridium plugs for my Honda a couple years ago before I new much about the metal resistance properties. I'll probably check them at about 40k.
