Thread: Wiring MAP sensor, L67 swap
Results 1 to 9 of 9
  1. #1 Wiring MAP sensor, L67 swap
    Greenville, SC
    swapped my L36 for L67, now i need to wire the map sensor. I have the new connector and all but dnt know which wires too splice.
    anyone?
  2. #2 Re: Wiring MAP sensor, L67 swap
    both your old map sensor and your new one should have the pinout stamped into it.
  3. #3 Re: Wiring MAP sensor, L67 swap
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    If you don't want to splice wires, you could just get the L36 to L67 MAP adapter:
    ZZ Performance
    It's pricey for what it is, but it makes it easy.
  4. #4 Re: Wiring MAP sensor, L67 swap
    Donating Users kfish's Avatar
    Ohio
    the colors should be the same, just match em up.
  5. #5 Re: Wiring MAP sensor, L67 swap
    If you have an L32 map sensor laying around...just extend the wires. It's the same wiring and connector as the L36.
  6. #6 Re: Wiring MAP sensor, L67 swap
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by kfish View Post
    This
    Or this.
  7. #7 Re: Wiring MAP sensor, L67 swap
    Quote Originally Posted by Reptile View Post
    This
    Or this.
    But disregard that sensors have the pinout right on them.
  8. #8 Re: Wiring MAP sensor, L67 swap
    Because who looks at those?
  9. #9 Re: Wiring MAP sensor, L67 swap
    Kansas City, MO
    Maybe I can't read? LOL
    OK, so for those color blind peeps....then there are the pinouts on the connector.
  1. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  2. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  4. Top Swap Wiring
    By AlldaySteve1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2010, 01:53 PM
  5. help: TB sensor pin-outs and wiring info needed
    By shaferz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 07:09 AM
