Thread: Supercharger noise (not the good one)
Results 1 to 14 of 14
  1. #1 Supercharger noise (not the good one)
    SE Level Member L KELLS's Avatar
    Chicago
    Hey guys how can u tell if a SC Coupler is bad. I have this noise coming from my SC and I want to believe its the coupler. It only do it at idle. Please HELP
  2. #2 Re: Supercharger noise (not the good one)
    Jul 2008
    sumter,south carolina
    if it sounds like rocks tumbling around the SC.. u have a bad coupler.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Supercharger noise (not the good one)
    Chicago
    I found out. I thot it was the coupler, so I took off the SC belt to see it itll stop but it didnt. Its a cracked flex plate (flywheel) I got underneath the car wit a flashlight and saw it.
  4. #4 Re: Supercharger noise (not the good one)
    Jul 2008
    that sucks... my flex plate cracked a few months ago... bad coupler would have been better.
  5. #5 Re: Supercharger noise (not the good one)
    Charles City, IA
    time to pull the engine.
    SMGPFC Two Nipple General
  6. #6 Re: Supercharger noise (not the good one)
    Jul 2008
    or trans
  7. #7 Re: Supercharger noise (not the good one)
    Charles City, IA
    If you like doing way too much work. I guess you could pull the trans. I would just spend 2hrs and pull the engine out the top.
  8. #8 Re: Supercharger noise (not the good one)
    Chicago
    Ill probably pull the engine out the top. Ive ordered my flexplate from zzp today. Im gonna change the oil pan gasket while its out the car. Im thinking of a mile cam as well
  9. #9 Re: Supercharger noise (not the good one)
    Charles City, IA
    I said the same thing when I pulled mine out to fix the oil pan gasket. Once you start you cant stop.
  10. #10 Re: Supercharger noise (not the good one)
    VS FTW that way.
    Might as well buy headers and a 3.4" too...whats another $250
  11. #11 Re: Supercharger noise (not the good one)
    GT Level Member jakewet28's Avatar
    Cincinnati
    ^X2
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  12. #12 Re: Supercharger noise (not the good one)
    Chicago
    My car is already moded as follows.....
    2002 GTP
    3.4 press on Thrasher pulley
    DHP v1.0 PCM
    MSD PRJ wires
    NGK TR55 plugs
    180 T stat
    Thrasher CAI
    Rebuilt tranny (twice) w/ shift kit
    UBend/Res Del
    2 1/2 custom Exhaust
    Flowmaster 40Series w/tips
    Polly upper motor mounts
    Storter dogbones
    ZZP Alt rewire kit
    ZZP Alt Voltage Booster adapter
    ZZP Valve Breather
    F1 hood
    Sd front air dam
    SLP Gen2 GTX wing
    CCFL Projector Headligjts
    6000k H1 HIDs
    6000k HID fogs
    Tinted altezza tails
    Cross drill/slot rotors
    High persuit/performance pads
    GXP RIMS.
    A piller guage pod w/ A/F ratio guage,
    Boost/vac guage and electric oil press guage
    Kicker Audio system 2 15" kicker L5 subs
    2 kicker 1000.1 mono bass amps
    Ive had my car for 6 years just hit 150,000 miles yesterday
    Got the car at 17,000 miles. In other words thats my baby
  13. #13 Re: Supercharger noise (not the good one)
    Nov 2009
    Grand haven
    Ok so all them mods and NO HEADERS? As nick stated above good time for headers and VS cam. I bet you would fall in love all over again with your gp. Oh and a good wideband tune.
  14. #14 Re: Supercharger noise (not the good one)
    Chicago
    Thats what im working on as well as an intercooler. Probably speeddaddy headers. Their cheep and they gets the job done. (so I hear)
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  3. supercharger noise
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 06:04 PM
  4. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
