Thread: Timing Chain Tensioner Noise?
Results 1 to 4 of 4
  1. #1 Timing Chain Tensioner Noise?
    AZ
    On my 2000 GTP I have an odd noise that really makes itself present at the tensioner pulley below the super charger. I thought coupler or tensioner. I replaced that, and the noise was still there. Took the belts off and its still there. It sees to be generating from behind the water pump and basically it makes the knocking type noise from idle to about 1200 rpm, and makes a kind of slap when you turn the car off. With the AC on, the noise is quieter. Does that sound like a timing tensioner issue?The sound is pretty much exactly what a coupler or bad tensioner sounds like. The car has been driving perfectly fine, and the noise has not gotten worse or louder since it began a couple months ago ( i dont drive the car too much) Any insight? Thanks!
  2. #2 Re: Timing Chain Tensioner Noise?
    Charles City, IA
    Might be the water pump going out.
    SMGPFC Two Nipple General
  3. #3 Re: Timing Chain Tensioner Noise?
    AZ
    would the water pump make that kind of slap noise upon turn on and shut down?
  4. #4 Re: Timing Chain Tensioner Noise?
    Charles City, IA
    It could if it was loose, but it might also be the chain like you said, check the pulleys for play.
  1. Timing Chain Replacement
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-07-2010, 12:11 PM
  2. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  3. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
