Thread: Car will not start, possible fuel pump fail
Results 1 to 5 of 5
  1. #1 Car will not start, possible fuel pump fail
    iowa
    Hello, i am new here so maybe someone here can help me. i just bought a 1998 grand prix gtp and has run fine up until now. i drove to the store, went in and when i came out it would not start. it will start and run for about two seconds then die. i think it could be the fuel pump but i can hear it run when the key is turned on so not sure if that could be it. i am going to test the fuel rail pressure tomorrow to see if we are getting gas but i wondered if you guys knew of any sensors that could cause this issue or something besides the fuel pump or filter. there were no codes that poped up. i am doing this myself because i dont feel like paying a shop to do what i can do myself but having fairly limited knowelge on computer run cars i could use all the help i can get.
    thanks
    osbornb
  2. #2 Re: Car will not start, possible fuel pump fail
    Willoughby, Ohio
    try unplugging your mass airflow sensor and see if it runs better. if so then the MAF is bad
  3. #3 Re: Car will not start, possible fuel pump fail
    iowa
    alright ill give it a shot thanks.
  4. #4 Re: Car will not start, possible fuel pump fail
    Jul 2008
    sumter,south carolina
    search on here for fuel pump resistor. its a common problem that matches ur description
    02 GTP with mods 05 GP for DD
  5. #5 Re: Car will not start, possible fuel pump fail
    iowa
    Yep, it was the fuel pump ballast resistor located behind the right front fender behind the light.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. fuel pump
    By acragon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 09:37 AM
  3. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
