Thread: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
Results 1 to 20 of 28
  1. #1 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    yep probably a leak. It works you will see the bubbles get pulled in, and the water around will bubble up as the waters drawn in
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    is the vac leak near the throttle body?
    1.9 Rockers- 42.5 injectors- 3.4" mps- Wizaired 104s- 180*- PRJ 10mm wires- SD headers 3" DP- Hp tuner- Dynotech stage 2- 3.29s 1'' chain
  3. #3 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Hagerstown,Md
    Quote Originally Posted by 02grandprix View Post
    Could be. Could also be at the Blower/Lim. Could be at the EGR tube. Could be vac line itself
  4. #4 Re: Map sensor reading goes from 35kpa to 65kp every 6 seconds?
    Apr 2009
    methuen
    No luck, maybe i ll grab some carb cleaner or starter fluid later on today and give that a try, or is there a better way to do it?
  1. Exterior Temperture Sensor reading OC
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 11:28 AM
  2. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  3. Car kills out after a few seconds
    By Kissner in forum General Tech Discussion
    Last Post: 03-16-2010, 07:32 PM
  4. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
  5. Please take 2 seconds and vote for us to get a strip
    By Z28 in forum Off Topic Discussion
    Last Post: 07-27-2009, 06:19 PM
