Thread: Weird Issue
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #1 Re: Weird Issue
    I already moved the injector when I replaced the o rings so I think that would eliminate the injector.
  2. #2 Re: Weird Issue
    Well then, I guess it is onto the ICM.
  3. #3 Re: Weird Issue
    I just noticed that the vacuum line to the evap canister is missing that couldn't cause a misfire could it? And where the heck is the evap canister at anyway, I couldn't find it.
  4. #4 Re: Weird Issue
    Jul 2008
    sumter,south carolina
    evap canister sits behind the blower.. its pointless bull****... but id fix teh vac leak.. doubt its the misfire cause but i could be wrong.
    02 GTP with mods 05 GP for DD
  5. #5 Re: Weird Issue
    vac leak would make it run lean and could cause a miss.
  6. #6 Re: Weird Issue
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    Something real similar to this happened to my friend just recently, he had a miss on cyl #5 and replaced everything and couldn't figure it out for a long time. It turns out in the end that his fuel trims were bad. We then Put the stock PCM back in an it ran perfect.
  7. #7 Re: Weird Issue
    I have a stock pcm.
  8. #8 Re: Weird Issue
    Dec 2010
    cny
    what kind of plugs are they,NGK is the way to go if not then delco are ok too,3.8s are picky bltches
  9. #9 Re: Weird Issue
    Autolite ap606 iirk.
  10. #10 Re: Weird Issue
    So I drove the car halfway across the state for work, then scanned it when I got home, now its putting up the code P0300 random multiple cylinder missfire. So I am more convinced that it is indeed a bad ICM.
  11. #11 Re: Weird Issue
    Well a little update on this here is a list of things I have replaced/removed trying to figure out wtf is going on.
    • Checked 800 times for vacuum leaks
    • New Autolite 104's gapped at .055
    • New Premium Wires
    • Swapped out all the coils twice
    • Swapped out the icm twice
    • Removed the cat
    • Removed Egr
    • Swapped injectors around
    • Replaced all the orings
    • Replaced new Powerbond SFI Harmonic Balancer
    • Replaced Crank Position sensor
    Still have random multiple misfires.
    This screen shot is from the car idling after a 15 min cruise down the highway. I tried to get a scan but when I opened the file it was blank
  12. #12 Re: Weird Issue
    Replaced Cam Position sensor today and still random multiple missfires........ that leaves only 2 more things that could be wrong the computer is bad or I have multiple chipped pistons.
  13. #13 Re: Weird Issue
    Went for a cruise down the highway for about 15 min, and my Timing Advance is all over the place while cruising its anywhere from 0* to -29.5* LTFT1 was pretty constant at -8.53975% had a short blip for a few seconds to -7.8125%
  14. #14 Re: Weird Issue
    So anyone have a spare engine they want to sell.
  15. #15 Re: Weird Issue
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by slick2500 View Post
    So what made you remove the head? Do a compression test first?
  16. #16 Re: Weird Issue
    Nov 2010
    Maryville, MO
    Ouch..
    my buddy has got one down here that he might want to sell
    let me know and Ill get a hold of him
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  17. #17 Re: Weird Issue
    This
  18. #18 Re: Weird Issue
    Apr 2009
    Fort Worth TX
    Even with that thumbnail post I can still see the damage. So you just noticed this recently?
  1. First Run on the track, and weird shifting issue
    By speedy2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2010, 03:41 PM
  2. weird cooling issue
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 05:44 PM
  3. weird car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 07-29-2010, 09:16 AM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
