and so basically when i tune my car when i run the breather cant i just program the pcv out?
Don't run a breather. You already have the fitting on the adapter to run to the PCV on the blower. Just get some hose from Napa or another place and run the hose from the PCV on the blower to the fitting on the adapter and you will be done. For blocking the EVAP all you need to do is get a screw that fits that hole and RTV a small piece of metal on there to block it off. Make sure you block the EVAP hole on the LIM if you are not going to run an EVAP at all though.
