Thread: Misfiring after Gen 5 install!
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Misfiring after Gen 5 install!
    SE Level Member deangtp's Avatar
    Kansas City, MO
    I told you it was the antithieving mod. If it's dirty maybe they won't try and steal 1500 dollars worth of crap out of my car......again. I'm just about done with this car too I think. New job on the horizon, mo money mo problems. On topic...I run a 3.1 on my Gen V
  2. #22 Re: Misfiring after Gen 5 install!
    Take a look at 99% of my posts... Your initial post is what led me to think you were doing mod after mod while having major issues. I'm not typically a dick, but when someone pops in and posts the way you did, catches me in the right frame of mind.... yeah once in a while I'm a dick too. Sorry. It was neat how you said misfires, didn't mention the kr because you don't have it (we assume it) and then a ton of mods added.
    Misfires w/o a cylinder doesn't make a lot of sense though. Even an Aeroforce would should it by cylinder.
  3. #23 Re: Misfiring after Gen 5 install!
    You cant pick up misfires via PCM if the P0300 code is disabled.
    If its not disabled then you will still have the other codes availible. (P0301-0306)
    Also with the aeroforce in the main menu there is an option called "Misfires" try selecting that and see what it says.
  4. #24 Re: Misfiring after Gen 5 install!
    Delaware, OH
    I'm throwing the guess of broken valve spring and/or chipped piston. need to do a compression test.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  5. #25 Re: Misfiring after Gen 5 install!
    Quote Originally Posted by benner View Post
    Would definitely be wise.
    And if things don't check out. A leakdown test would be the next logical step.
  6. #26 Re: Misfiring after Gen 5 install!
    Leakdown should always be the first thing to do...I think its fairly easy.
  1. SS M90 misfiring due to tune?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 10:38 PM
  2. Misfiring
    By Kazmoe in forum General Tech Discussion
    Last Post: 02-20-2010, 07:10 PM
  3. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  4. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
