I had the same problem except it was the ABS and TCS OFF lights. Replacing both front hubs fixed it.
Also check out the level in your power steering fluid reservoir since you felt the PS get stiff. It's below the alternator next to the bottom of the coolant overflow tank. Remove that tank to easily access the PS reservoir.
