Thread: ABS and check tire pressure light on
Results 1 to 5 of 5
  1. #1 ABS and check tire pressure light on
    SE Level Member GTP2188's Avatar
    Benton, Arkansas
    Hey everyone,
    I am having a problem where when I'm driving down the road my ABS and check tire pressure light come on randomly. The only thing I notice that it is making my car do is the steering gets stiff when turning. It goes off though after I turn the car off but when i start driving again it comes back on it used to do this a year or so ago and quit, but now its doing it again. What could be the problem? and yes i know this is in the engine thread but no one was answering it in the brakes thread
  2. #2 Re: ABS and check tire pressure light on
    Charles City, IA
    You've gotta wait more than 2 hrs for an answer. Its more than likely a bad wheel speed sensor in one of the hubs, have a shop scan the abs codes and that will lead you in the right direction.
    SMGPFC Two Nipple General
  3. #3 Re: ABS and check tire pressure light on
    Benton, Arkansas
    ok i will try that
  4. #4 Re: ABS and check tire pressure light on
    SE Level Member Paul79UF's Avatar
    Florida
    I had the same problem except it was the ABS and TCS OFF lights. Replacing both front hubs fixed it.
    Also check out the level in your power steering fluid reservoir since you felt the PS get stiff. It's below the alternator next to the bottom of the coolant overflow tank. Remove that tank to easily access the PS reservoir.
  5. #5 Re: ABS and check tire pressure light on
    Benton, Arkansas
    The power steering pump on my car is in the same place but the coolant overflow is by my PCM and air intake. I will check the hubs if it's them I'm going to be pissed. I have replaced them for different reasons at least 8-9 times!
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. ABS and check tire pressure light on
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2010, 07:00 PM
  3. Check Tire Pressure?
    By 04gpking85 in forum General Tech Discussion
    Last Post: 02-11-2009, 01:06 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
