Murray has been around for quite awhile...in fact...I've always remembed even my old man buying Murray branded parts when I was little when he used to work on cars.
I found this from Autozone...Will this work?
Part Number: CU1890
Weight: 12.5 lbs
Warranty: Limited Lifetime
Notes: 1 row, 30 1/2" x 15" x 1" core size
Make: GM
Core Size: 30 1/2 x 15 x 15/16 inch.
Number of Rows: 1
Inlet Tank: 2 7/16 x 16 9/16 inch.
Outlet Tank: 2 7/16 x 16 9/16 inch.
Inlet: 1 5/16 inch. Top Left
Outlet: 1 5/16 inch. Bottom Right
Mounting Type: Saddle/Pin
Transmission Oil Cooler: 11 1/2 inch.
Engine Oil Cooler: N/A
Notes: Sensor Fitting on RH Tank
Here is the one from O'Reilly...
Murray - Radiator
Part Number: 432425
Warranty Info
Limited Lifetime Warranty
Detailed Description
* Core Size: 30 1/2 x 15 x 15/16
* Construction Material: Plastic Tank Aluminum Core
* Rows: 1
* Tank Inlet: 2 7/16 x 16 9/16
* Tank Outlet: 2 7/16 x 16 9/16
* Inlet Connection: 1 5/16 Top Left
* Outlet Connection: 1 5/16 Bottom Right
* Mounting: Saddle/Pin
* Transmission Oil Cooler: 11 1/2
