Thread: Help, Car Won't Start.
Results 1 to 2 of 2
  1. #1 Help, Car Won't Start.
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Come from work this morning and all i wanted was to get some sleep. Then my mother wants me to go to the bank with her to help cash some money orders. We drive to the Citibank and do what we needed and come out to start my car and it wont turn over. I dont even hear the little "WHINE" noise the fuel pump makes when you put the key to acc. I then ruled things out and went and bout a delco pump which cost me $320. I install it and my fuel gauge wasn't even moving with the new pump. I take it out and install the old pump back in and the gauge is back to working but car still wont turn over. I look under the hood and check the fuel pump fuse and its fine. I switch the fuel pump relay with the Daylight running light relay and try to start the car and still nothing. I replaced the fuel pressure regulator just last month with a auto zone brand. Don't know what else could be the cause but im not giving up.
    No check engine lights or codes what so ever.
    i need wise advice, help and guidance.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Car wont start SMHHHHHHHH....
    New Brunswick
    If you try starting and leave the key to on when you release does the padlock icon show on the message center in the cluster?
    Keep the doors closed while you check for this.
  1. Rev's at start up
    By 2003GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2010, 06:58 PM
  2. No start. Need help!
    By Phurst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 09:09 AM
  3. Car Won't Start!!!!!!!!!!
    By mminchau in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 02:21 PM
  4. 04 gtp, tic tic tic tic when trying to start
    By busagtp in forum General Tech Discussion
    Last Post: 08-31-2009, 08:26 AM
  5. where to start
    By Jakegday in forum PCM Tuning
    Last Post: 08-04-2009, 12:51 AM
