Thread: Rev's at start up
Results 1 to 8 of 8
  1. #1 Re: Rev's at start up
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    IAC gummed up or bad? What car and how many miles?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  2. #2 Re: Rev's at start up
    Edmonton AB
    The car is a 2003 GP GTP. It has 120,000 km ( Im in Canada ). It has done this for a while though. Probably started around 80,000 km.
    Thanks
  3. #3 Re: Rev's at start up
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    99% sure its the idle air control valve. you can try and clean it first with some carb cleaner. if not then jusr replace it.
    2000 Daytona GTP(aka the slow fwd GTO)
  4. #4 Re: Rev's at start up
    Edmonton AB
    Thanks you for the reply. I will try to clean the IAC. Can you tell me where I would find it exactly?
    Thanks
  5. #5 Re: Rev's at start up
    Nov 2009
    Michigantown, IN
    kinda like this right here. itll be on your throttle body. you cant miss it
  6. #6 Re: Rev's at start up
    Edmonton AB
    Excellent. Thanks alot man. I really appreciate it. I have some sensor cleaner I used on the MAF a while ago. Im going to hit it with that and see what happens.
  1. where to start
    By krimsonwolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 05:03 PM
  2. Car Won't Start!!!!!!!!!!
    By mminchau in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 02:21 PM
  3. Where should I start?
    By Basher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2009, 09:44 PM
  4. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
  5. Help car won't start
    By gtora69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 05:48 PM
