Thread: Intercooling Options
Results 21 to 40 of 70
  1. #21 Re: Intercooling Options
    ontario
    bedwards,
    i have the ssic setup from zzp with a stage 3 fmhe, i have yet to install it as i want everything to be figured out before i do. it is my daily driver.
    so far from what i can see, the only clearance issue is where zzp puts the fpr on the ssm90 fuel logs (the front log) and the fuel line already is rubbing on my hood brace. the fix as far as i can see would be to move the fpr to the back log which would allow for clearance (this is how zzp non ssm90 fuel logs come)
    the other thing would be belt size obviously cause your moving the pulley up.
    for the actual functionality, its going to depend on how hardcore you want to go with your car.
    as for the "i can touch the s/c after 20 wot runs" i dont understand how this is possible as the intercooler is cooling the air after the s/c. so logically the s/c is still drawing in ambient temperature air.
  2. #22 Re: Intercooling Options
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by 02bluegtss View Post
    bedwards,
    Thanks for the reply. On my SS M90, the FPR is on the back logs. I have a feeling the clearance issue would be that the FPR being raised up 2.5" would cause it to hit the hood. I'm curious if IRC would make a core to match the size on the SSIC, but use the better material (superior to ZZP's) to prevent heat soak.
  3. #23 Re: Intercooling Options
    Vancouver, WA
    Email Marty, the owner. He will literally make anything within reason that you can draw up. Their IC is already shorter than the stage 2 ZZP so you might want to see if it will fit, find out the clearances. As I said before the bar and plate design is much better than ZZP's so if you had a SSIC and a similar size IRC bar and plate the bar and plate would be much more efficient.
  4. #24 Re: Intercooling Options
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Bedwards View Post
    I have the ZZP fuel logs. That's why I'm confused why a 2.5" intercooler won't fit. ZZP claims there are clearance issues. I have no idea what that means. I wonder if the machined lower intake is higher than a stock one? In that case, it may not clear the hood. You apparently need injector spacers with the intercooler as well (SSIC).
    It will clear the hood, The issue isnt height clearance. Its the fact that our injectors are so close to the Blower because there in the LIM. Wbody dtores can be hacked down. I have no issue with my SSIC. I like it. Is it as good as a full size? NO. Does it do a decent job? yes
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #25 Re: Intercooling Options
    Hagerstown,Md
    Quote Originally Posted by footballplaya3k View Post
    Actually the bar and plate has been tested and shown to be less efficient because of the size
  6. #26 Re: Intercooling Options
    Quote Originally Posted by 01gpgt01 View Post
    But wouldn't injector spacers solve that problem? I must not be understanding this properly. Lol.
    Were you able to drop a pulley size with the SSIC, and stay KR free?
  7. #27 Re: Intercooling Options
    Hagerstown,Md
    No because because the core is where the injectors are. You have to Notch the core to go around the injectors. Im pretty sure the PCV passage is where a injector sits on the s2ic
  8. #28 Re: Intercooling Options
    Hagerstown,Md
    I was able to run 20 degrees WOT timing on a 3.4 pulley on 93 pump gas with no valvetrain mods. You be the judge
  9. #29 Re: Intercooling Options
    Wow.
  10. #30 Re: Intercooling Options
    Hagerstown,Md
    Wow.
    Thats on l36 compression and little to no knock. Id get some KR here and there But always under 1 degree. Most runs no knock though, and that was with 02's in the 910-915 range
  11. #31 Re: Intercooling Options
    You have a top-swap or SS M90?
  12. #32 Re: Intercooling Options
    Hagerstown,Md
    SS m90
  13. #33 Re: Intercooling Options
    SS m90
    Who did your tune?
  14. #34 Re: Intercooling Options
    Hagerstown,Md
    Who did your tune?
    Myself
  15. #35 Re: Intercooling Options
    Myself
    I sent you a PM.
  16. #36 Re: Intercooling Options
    Vancouver, WA
    Tell PRJ that.
  17. #37 Re: Intercooling Options
    Hagerstown,Md
    Tell PRJ that.
    I dont have to the Facts are out there. Like it or not. Im not saying there no good but look around there was just a huge post on club gp regarding. PRJ's core is a great core, Believe its the same thrasher uses.Its very expensive. Ive heard its comparable to zzps or W bodys stage two. All things being equal the fins better IMO. At least on these heatons. For a Heat exchanger bar and plate ftw
    Here I did the research for you. Enjoy http://www.clubgp.com/newforum/tm.as...anguage=single
  18. #38 Re: Intercooling Options
    Here I did the research for you. Enjoy ClubGP Message Forum troubleshooting
    Whole lot of "this guy said so" going on in there.
    Edit: unsure about WBS guy. Seems he might have a hair of honesty but still undecided. "we tested it" doesnt hold much imo.
  19. #39 Re: Intercooling Options
    Hagerstown,Md
    Thats the owner of W-Body store. Yeah I think hes had some experience with them lol
  20. #40 Re: Intercooling Options
    Hagerstown,Md
    bedwards,
    Your fuel line will be tight to on the blower when you install the SSIC after you put the log with the fpr on the rear bank. i just put some pipe wrap around where it was touching the snout slightly
  1. TB and MAF Options ?
    By Lawngoose in forum General Tech Discussion
    Last Post: 08-23-2010, 07:59 PM
  2. Intercooling or Meth/Water Injection
    By Ttypel67 in forum General Tech Discussion
    Last Post: 06-21-2010, 01:07 AM
  3. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
  4. Intercooling
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 10:56 PM
  5. PCV and Intercooling
    By TooMch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 11:21 AM
