Thread: My Billet rotor block
Results 1 to 12 of 12
  1. #1 My Billet rotor block
    SE Level Member vsl67's Avatar
    Australia
    I havent been on here much but heres what Ive been up to After some dramas with my rotors ,I Decided with help from engineers and supercharger experts to make a rebuildale Rotor block that uses of the shelf seals and has adjustable clearances between the rotors and the block ,Also the rotors are locked into place to stop the rotors from working their way into the rear of the case which has happened in the past ,also the recess between the rotors and block has been eliminated I think this has caused the increased induction noise at idle it sounds like a jet power up
    Its only in the testing stage at the moment but is going well
    Im not going into too much more detail except to say this is a bit more than a machined piece of billet
  2. #2 Re: My Billet rotor block
    wait a minute...someone doing ACTUAL fab work for their car? no ****ing way.
    props to you, sir. mad props.
  3. #3 Re: My Billet rotor block
    Windsor (ON) Canada
    wooowww purdy!!!
  4. #4 Re: My Billet rotor block
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Nice work. Glad to see someone else does mods like I do... I figure anything will fit with a blow torch, saws-all and a Bridgeport mill.
    Lambokit to be built!!!!!
  5. #5 Re: My Billet rotor block
    Apr 2009
    Radford, Virginia
    Ummm by the way what kind of car is that???
  6. #6 Re: My Billet rotor block
    Topeka, KS
    Appears to be a Holden. Judging from his location of Australia and his avatar pic.
  7. #7 Re: My Billet rotor block
    Apr 2009
    Radford, Virginia
    Hell of a bad a$$ engine compartment. I thought the pic had been inverted because of the brake booster and master cylinder until I saw that he was from Australia... Coursw I'm a little slow anyways... hahaha
  8. #8 Re: My Billet rotor block
    from his intro thread:
    his is my 98 VS L67 Holden statesman
    since you all are too lazy to search for 5 seconds.
  9. #9 Re: My Billet rotor block
    Apr 2009
    Radford, Virginia
    really BIO???? You felt you needed to go there? Nice. I was just commenting that I liked his ride and wondered what it was. I did look at his profile and nothing was there. So I asked. Anyway... Nice machine work vsl67!!!
  10. #10 Re: My Billet rotor block
    Sex.
    I need some rotors from down under with all the sexy coating if your still doing that.
  11. #11 Re: My Billet rotor block
    Australia
    Yeah you can send them directly to HPC if you want they should be cheaper for you guys as your dollar is usually stronger then ours and actually that coating is a experimental anti friction coating its abit different from the blue coating I use to use (alot stronger)
    the contact details are on the rotor rebuilding thread
  12. #12 Re: My Billet rotor block
    SE Level Member BlackGS's Avatar
    Central Jersey
    That is some nice work!
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  1. Billet accumulator pistons?
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-21-2010, 10:39 PM
  2. Billet Caps
    By TNTSS in forum Visual/Body Modifications
    Last Post: 08-01-2008, 11:56 PM
  3. ZZP Billet TB
    By TNTSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2008, 04:16 PM
  4. Billet 78mm TB - looks sweet
    By IndeedSS in forum Off Topic Discussion
    Last Post: 05-09-2008, 06:24 AM
