Thread: Autolite XP103 Xtreme Performance Iridium Spark Plugs
Results 1 to 8 of 8
  1. #1 Autolite XP103 Xtreme Performance Iridium Spark Plugs
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Would anyone recomend these for a fully built L32?
  2. #2 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    Charles City, IA
    what fully built? twin turbo with all the custom fixins?
    SMGPFC Two Nipple General
  3. #3 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    Round lake, IL
    Not twin turbo lol, it was 03impala9c1's car Fully Built 4T65e-HD (23K miles)
    -TEP master overhaul kit
    -ZZP 7/8 3.29 gear and chain set
    -INTENSE 300m input shaft
    -Hardened 4th clutch shaft
    -ZZP chromoly pump shaft
    -ALL new Borg Warner/AC Delco solenoids
    -Dynamat False Knock Elimination Kit
    -more i cant think of
    ZZP 3K Stall Converter
    42K 2006 L32 (2k on parts)
    -Fresh paint (professionally) (black)
    -Whitcomb painted Gen V
    -Whitcomb painted/filled valve covers
    -NIC cam
    -LS6 valve springs and retainers
    -Viton Valve Seals
    -Modded LIM
    -GM Aluminum LIM Gaskets
    -Aluminum oil pan
    -ZZP oil volume kit
    -EGR delete
    -EVAP delete
    -Lucas 42.5# injectors
    -ZZP MPS System with 3.0 pulley
  4. #4 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    Charles City, IA
    Those plugs wold work fine for that car. When I think fully built I think alumin heads, custom cam, gen-v or larger blower, diamond pistons balanced rotating assembly, etc....
  5. #5 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    iridium?
  6. #6 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    Topeka, KS
    Why not copper ?
  7. #7 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    AL103's.
  8. #8 Re: Autolite XP103 Xtreme Performance Iridium Spark Plugs
    Iridium plugs are made of a tougher compound than copper, they usually have a fine point tip to them and therefore the tip gets hotter. Getting a hotter spot in the cylinder means the chance of predetonation is more likely.
    Food for though.
  1. What spark plugs should I get??
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2010, 11:13 PM
  2. Spark Plugs?
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 03:13 PM
  3. Spark plugs, etc.
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2010, 06:52 PM
  4. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  5. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
