Thread: Surging idle when warm
Results 1 to 20 of 24
Threaded View
  1. #1 Surging idle when warm
    Donating Users kfish's Avatar
    Ohio
    After a moment of rage, and a backwards burnout with the traction control on, my idle jumps from 500-2000rpm. My short term fuel trims are sitting at 128, and the pcm commanded afr is around 13.8:1. The 02 readings are around .480mv, never higher. They do not switch like they are supposed to. What I dont understand is how can the pcm be commanding a rich afr like that, but the 02 not show that? Im throwing 2 codes, maf circuit a low input, and now 02 bank 1 sensor 1 no activity. no vacuum leaks, no exhaust leaks. Ive put a new maf on, cleaned the tb, and cleaned the iac. HELP ME!
  1. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  2. Warm engine won't idle.
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2010, 04:51 AM
  3. Surging idle under normal acceleration
    By billy8380 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 10:36 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
