01 GT, been having problems with the engine dying at idle. Starts cold fine, once it's up to op temp, the idle drops to 450-500 and then drops out. Re-starting only if the throttle is held down. I've replaced the TPS, MAF and MAP, cleaned the IAC, IAT and EGR. No vacuum leaks, good fuel pressure. It has given a code of P0327, Bank 1 knock sensor input low. I'm TOTALLY stumped and ready to drive the thing into the bay.![]()
