Thread: going cammed?
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: going cammed?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Maybe alittle of both
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #22 Re: going cammed?
    we shall see in due time.
  3. #23 Re: going cammed?
    Dec 2008
    Canada
    Wild is where its at.
    This
    Quote Originally Posted by SilvaMan61 View Post
    no i read through that already.. im to stupid to make heads or tails from these numbers. i know what the sh!t is i just dont understand what the numbers translate too
    should have included that in my original post
    There are videos out there to help you, in school we watched degreeing and reading a cam.
    I am talking about the machining and checking it for clearances, where stock replacement is pretty much plug and play.
    Last time I was looking at this i thought you could buy the cover already machined for like just a bit extra cash? Not only that don't be a baby I don't see why people are scared of dbl rollers.
  4. #24 Re: going cammed?
    becaused they're made and designed for austrailian 3800's which have less chamfer on the crank gear.
    If you dont correct that, then buh bye timing chain.
    and yes, you can buy machined oil pump covers.
  5. #25 Re: going cammed?
    Dec 2008
    Canada
    I never knew they were made for the aussie 3.8 :/ That seems kind of dumb to me, but I know locals who are still running them not for very long yet (about 2k or so) and haven't run into a problem yet maybe I will inform them.
  6. #26 Re: going cammed?
    The old school ones were for our engines, but the only ones that are availible new are not designed for our engines.
  7. #27 Re: going cammed?
    As long as the gear is machined down to be the same height as the stocker sitting next to it...then it'll be fine and you won't have that horrible failure that people were making the Double Roller out to be. Also keep in mind...you have to X the balance shaft to run a Double Roller too since the Aussie motors don't have those AND they have more oil ports for the cam on the lifter valley...which I was going to have done...but figured...meh, screw it.
  8. #28 Re: going cammed?
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    i most likely want the most simple cam i dont wanna be changing heads, and i drive this car alot so i really cant go to heavy of a cam anyway
  9. #29 Re: going cammed?
  10. #30 Re: going cammed?
    Charles City, IA
    I say vs also.
    SMGPFC Two Nipple General
  11. #31 Re: going cammed?
    I say big cam...and love it like me.
  12. #32 Re: going cammed?
    Nov 2009
    centereach, NY
    how much did it cost for the entire the parts and labor all together approx?
  13. #33 Re: going cammed?
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    Do it right? The XP isn't even NEAR rough enough to run a double roller, even with 105's...cmon dude. A new chain and stock dampner work great.
    i would rather have over kill than not enough, better safe than sorry.
    2000 Daytona Pace car, SD Hood, Xp cam, Ported Heads, Gen V, North Star, Headers, ZZP stage 2 Intercooler, 3in Exhaust, and custom tune
  14. #34 Re: going cammed?
    Quote Originally Posted by RICE KILLER View Post
    I agree, but an XP is a tiny cam.
  15. #35 Re: going cammed?
    Vancouver, WA
    If you want to be overkill why did you get the ls6 springs instead of 105's
  16. #36 Re: going cammed?
    Quote Originally Posted by footballplaya3k View Post
    #90 LS6 springs/retainers are even rougher on the valvetrain than 105's...sooo...not really seeing your point. They are just as good as 105's and get the job done...I shifted over 6300 with the XP and 90's. No float or anything there. BUT, 44K or whatever on a new chain/dampner...it chewed up the dampner pretty good.
  1. more proof that this guy lied! it cant be cammed
    By boostedgtp13 in forum The Rant Forum
    Last Post: 05-12-2010, 03:15 PM
  2. newb with a top swapped cammed GT
    By Mater in forum Introductions/Noob Questions
    Last Post: 02-27-2010, 10:21 PM
  3. cammed 3.1 SE
    By ricardo23 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-12-2009, 05:36 PM
