Ok so I have a 2000 GTP and I started noticing about a month ago small drips of power steering fluid under my car. Then a few days ago my pump started whinning really bad.
I did a little research and many guys have problems with the pressure line. Well I got underneath and looked around and all my lines look ok. The return lines are pretty clean along with my pressure line. The bottom of the reservioir was covered in fluid and the little sensor attached to the reservoir
So I filled up the ps reservoir and ran the car for a while but cant seem to find anything unsual or any leaks. I just see fluid on the bottom of the reservoir and a sensor. Any body have advice for me? Is the pump shot?
Please any advice will help. Thanks
