Hey all, I do not post on here much. I have some parts that have been waiting way too long to go on the car and am finally getting around to installing everything. So, I am looking for some basic help and guidance. Thanks in advance!
The car currently has the mods listed in my signature...pretty basic stuff. I have a 2" IC setup as well as 1.8 rockers waiting to go on. First off, are there any decent write-ups on these installs anywhere? I have found one or two for the rockers, which are just ok, but not a lot of good information out there. Otherwise are there any generic/standard sort of tips and warning for doing this?
The IC has a ported lower intake with it. I was digging around and actually found someone suggesting that there was little to no difference to be gained from it...and I would like more input on that. If there is little to be gained in my situation, I would rather save the effort, sell the ported LIM, and save the $50 on gaskets. Yea, and why are intake gaskets $50?!?
From there I have questions about pulleys. More reading leads me to believe that it is cheap insurance to upgrade to a metal 3.5" idler pulley, so I will pick one up. I also think that a 3.2" pulley is as far as I can safely go without upgrading injectors. With that said, does anyone have any clue what belt would work with a 2" core, 3.2" pulley, and 3.5" idler pulley? On top of that, any idea if I might be able to get away with the same belt with the 3.4" pulley until I get my hands on a puller?
Then on to spark plugs. What is the rule of thumb there? Any suggestions for a specific plug, as well as gap? Any other ideas, such as where to put the IC pump and how to wire it? I remember also reading that the alternator and/or coil pack has to be shimmed, is that right?
I am sure there are more newb questions that I will come up with, but any and all support to start is appreciated.
