Quote Originally Posted by Andrew_99GTP View Post
Just so you know your sig doesn't show up. As far as the ported lower intake goes I never had one or never have installed a W2A IC (water to air). But from what I have read to get the most out of one you want to have your lower intake ported and your s/c ported for an IC. Which at the very least involves removing the "wall" on the outlet side. What brand and version IC do you have. Because I know the zzp ones need to have the ported lower intakes to keep the pcv function function able. You should be fine with your stock injectors down to a 3.1 pulley but you should do something like a fuel pump rewire. But also how far you can push your stock injectors also depends on the condition of your fuel system, like the pump, and filter.
HTH
I am not sure what is up with the signature, I am adding it manually here. I do not plan on porting the blower. I believe this is an Intense 2" intercooler, as I know it is not the MAP one...the core on this one is pretty good. I will be sure to add in the fuel pump rewire...are there any instructions on that floating around? I am curious as it how intensive it will be before I get into it.
