Thread: Handful of Questions for an Intercooler Install
Results 1 to 13 of 13
  1. #1 Re: Handful of Questions for an Intercooler Install
    Jan 1970
    Maquoketa, Iowa
    The fuel pump rewire requires you to open your trunk, unbolt a couple of bolts and plug it into the fuel pump, find a nice ground and then run it to the front of the car to the fuse box.
    I'm not sure on Intense's IC need for LIM porting. But regardless, all that happens is you knock a section out of the LIM like andrew said, not too extravagant but it is better off you do it and get done with it.
    You can get a I/C pump relay from W-body store I believe for wiring.
    It is best to find someone local to help you, or to buy a full kit with directions, but since you already have the stuff, it will take a little patience to learn how to do it right and a lot of good judgement on who you listen to on here.
  2. #2 Re: Handful of Questions for an Intercooler Install
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    The only reason I mentioned porting the blower was to allow you to get full use out of the IC. Maybe this link will help INTENSE-Racing.com: <b><i>INTENSE</b></i>™ Ported Gen 3 M90 Supercharger Housing
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  1. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  2. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
  3. Intercooler radiator
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 12:29 PM
  4. Intercooler Spray Bar Kit...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 12:18 AM
