Thread: Draining coolant..
Results 1 to 11 of 11
  1. #1 Re: Draining coolant..
    Kansas
    Quote Originally Posted by QUICKSILVER462 View Post
    Did you change your coolant yet?
    I can tell you how to get the fluid out of the radiator the easy way, without spilling a drop or making a mess, well the mess part is up to you. You don't have to open the drain or take off any hoses.
    Dean
    why dont you tell everyone?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Draining coolant..
    Jul 2010
    apopka, fl
    don't forget about draining the block... to do you have to remove the two knock sensors one one each side of the block to get all the coolant out. the front sensor is easy the back is a trick....
    99 Black GTP 3.25 sc pulley, E85 fuel conv., 3" DP w/ hi flo conv., walbro FP, 180 stat, FW intake, zzp pcm, 104s plugs, AMSOIL, AEROSHELL Turbine oil for SC oil
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
  3. Coolant
    By kaiser0427 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2009, 08:03 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. Draining Coolant Completely
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 10:55 AM
