Thread: Draining coolant..
Results 1 to 11 of 11
  1. #1 Draining coolant..
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I was wondering how do i drain the current coolant from the car? The shop my car was at seemed to have added the wrong coolant (Green stuff) instead of Dexcool (Brown stuff).
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Draining coolant..
    GTX Level Member cerick08GP's Avatar
    The best way is by taking off the lower radiator hose. The actual radiator drains on our cars is a POS and its a PIA to get to.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Draining coolant..
    Bowie, MD
    Thank you cerick. I appreciate it.
  4. #4 Re: Draining coolant..
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Lot of people flush out there cars to run the green stuff. I usually run th eyellow stuff in my cars.
    My EX wifes other car is a broom.
  5. #5 Re: Draining coolant..
    green is better than dexcool
  6. #6 Re: Draining coolant..
    Charles City, IA
    Dex is orange not brown.
    SMGPFC Two Nipple General
  7. #7 Re: Draining coolant..
    HUDSON
    Did you change your coolant yet?
    I can tell you how to get the fluid out of the radiator the easy way, without spilling a drop or making a mess, well the mess part is up to you. You don't have to open the drain or take off any hoses.
    Dean
  8. #8 Re: Draining coolant..
    Kansas
    Quote Originally Posted by QUICKSILVER462 View Post
    Dean
    why dont you tell everyone?
    SOLD 1999 GT Silvermist TS
  9. #9 Re: Draining coolant..
    Jul 2010
    apopka, fl
    don't forget about draining the block... to do you have to remove the two knock sensors one one each side of the block to get all the coolant out. the front sensor is easy the back is a trick....
    99 Black GTP 3.25 sc pulley, E85 fuel conv., 3" DP w/ hi flo conv., walbro FP, 180 stat, FW intake, zzp pcm, 104s plugs, AMSOIL, AEROSHELL Turbine oil for SC oil
  10. #10 Re: Draining coolant..
    HUDSON
    To drain the radiator, goto hardware store and get a four foot section of clear vinyl tubing, the longer the better, its cheap anyway. Put one end in the radiator all the way to the bottom. The other end of the tubing should be as low as possible, and just give a quick suction to the end, and put into container you want. The longer the hose, the better, for obviouse reasons. I leave a about two coils on the ground that way it gives more distance from your mouth to the coolant,LOL. You can stop the flow just by lifting out of the radiator. It comes out quick. This method will have the radiator drained before you would even think of finding the factory drain peepcock. And it's not going to splash all over the place like when it exits the lower radiator hose, if you have ever done that way before, and like taking a bath in ethylene glycol, or whatever it is in there, rust? If you worried about not getting all the coolant out, just refill radiator with water, run motor for a minute, repeat draining with hose.
    Dean
  11. #11 Re: Draining coolant..
    Kansas
    smart man
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
  3. Coolant
    By kaiser0427 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2009, 08:03 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. Draining Coolant Completely
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 10:55 AM
