Thread: harmonic balencer blow out?
Results 1 to 10 of 10
  1. #1 harmonic balencer blow out?
    Donating Users gtp239's Avatar
    ft myers fl
    Alright heres the deal im at the gas station and suddenly there is this clicking kinda noise coming out of my engine i get out and look it sounds like its coming from the belt area.
    I drive home like 3 blocks and it stops when not at idle turn the car off and look under hood the rubber on the harmonic balancer looks like part of it exploded and it wasnt like that before .
    My question is about the new balancer for sale on rock auto the one by acdelco says new key required. so i cant use the old one?
    also any tips or would be great because iv never changed one before.
    Thanks in advance.
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  2. #2 Re: harmonic balencer blow out?
    I simply pull them and replace. Although there's very few SII motors that I've seen them degrade on. Probably because they aren't quite as old as the Si's that seem to go.
    If you want to save a little, I have 2-3 laying around that I'd toss one at you super cheap.
  3. #3 Re: harmonic balencer blow out?
    ft myers fl
    also what kinda of puller should i use where can i get it
    I know you guys are picture whores so here is some pics of the damage
    http://i930.photobucket.com/albums/a...CN2305_002.jpg
    http://i930.photobucket.com/albums/a...CN2304_003.jpg
    http://i930.photobucket.com/albums/a...CN2303_001.jpg
  4. #4 Re: harmonic balencer blow out?
    Charles City, IA
    ZZ Performance
    one like this, but go to autozone or advance etc....They are like 15 bucks there then go to the hardware store and get 3 grade 8 1/4-20 bolts that are like 100mm long.
    SMGPFC Two Nipple General
  5. #5 Re: harmonic balencer blow out?
    ft myers fl
    thanks for the offer bill but i already ordered one
    and i will deff piece together my own puller thanks for the specs
    should get all parts in the next few days ill let u know how it goes.
    wish i had the money for a cam since ill be down there anyway
  6. #6 Re: harmonic balencer blow out?
    Charles City, IA
    Pulling the balancer off is a lot easier than doing a cam.
  7. #7 Re: harmonic balencer blow out?
    Technically the puller bolts are M6 x 1.00 x 80mm (if you go longer on a GP, you tend to have the body int he way. The 1/4's will work fine because the overall threads etc are close.
    My shelf hates that you already bought one.
  8. #8 Re: harmonic balencer blow out?
    ft myers fl
    my self hates that i already bought one also
    i understand that there is more to a cam than balancer, springs, retainers, timing chain just sucks that ill be down there looking at it and cant change it
  9. #9 Re: harmonic balencer blow out?
    Charles City, IA
    You will not be any where close to looking at the cam.
  10. #10 Re: harmonic balencer blow out?
    ft myers fl
    got it fixed ended up using 1/4-28 bolts the m6s wouldn't thread all the way in and did not try the 1/4 20s
  1. How do you get the crank pulley/harmonic balancer off???
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 11:08 PM
  2. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  3. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
  4. Any advice removing old harmonic balancer?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-09-2009, 06:35 PM
