Thread: sorting through some KR problems
Results 1 to 14 of 14
  1. #1 sorting through some KR problems
    Jan 2009
    Tallahassee, FL
    I'm getting spikes of KR in the top end randomly. Sometimes it's 0* and has only gotten as high at 3*, usually it's around 1*-1.5*. I'm running a 3.4" setup right nowand had no KR on the stock tune and recently went with a DHP tune and that't when it started popping up. Only spikes when I'm in the very top end before it shifts. I have no way to get a scan of what the car is doing, do have a KR scanner. Trying to figure out if this is false since I need to replace the blower coupler and have a chipped piston right now as well. What is everyone's thoughts on this?
    3.4", ported blower, plog, catless DP, !u-bend, 180* thermo, K&N cone, DHP.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: sorting through some KR problems
    3* isnt false in the least and is not that much. its fairly typical for your level. you need a good custom tune now.
  3. #3 Re: sorting through some KR problems
    Just kinda a lame thing to mention...but do you have stock plugs/wires? If not...toss some new wires with AL104's in there...that should kill some knock...with those mods your car is going to need a cooler spark.
  4. #4 Re: sorting through some KR problems
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Sandman View Post
    I'm getting spikes of KR in the top end randomly. I need to replace the blower coupler and have a chipped piston right now as well. What is everyone's thoughts on this?
    Re-Read that a few times and let me know what you find wrong with those words.
  5. #5 Re: sorting through some KR problems
    LOL wtf...good catch schmee.
    It's called a new bottom end...look into it.
  6. #6 Re: sorting through some KR problems
  7. #7 Re: sorting through some KR problems
    Obviously neither of us do
  8. #8 Re: sorting through some KR problems
    Bastard Reptile's Avatar
    Kansas City, MO
    Chipped piston could very well be a problem to, and if it's not the cause of this, it will be an issue later on if you keep pushing it.
  9. #9 Re: sorting through some KR problems
    OOOOOO!! Pick me! I know what its like driving with a chipped piston!!
  10. #10 Re: sorting through some KR problems
    Jan 2009
    Tallahassee, FL
    I'm collecting parts to fix the piston right now, trying to get a hold of a larger Thrasher pulley. As for ignition I'm on stock coils and new wires, been running 104s.
    77 Morris Garage B
  11. #11 Re: sorting through some KR problems
    If you got a chipped piston...I wouldn't be beating on it to see what levels of KR you have...you might still be able to save the block and crank.
  12. #12 Re: sorting through some KR problems
    Jan 2009
    Tallahassee, FL
    I haven't been beating on it really. The motor has been this way since spring break. I'm almost ready to pull the motor.
    77 Morris Garage B
  13. #13 Re: sorting through some KR problems
    I'm just going fomr the fact you were saying you were getting KR in your top end...which means high RPM...which means WOT for the most part.
  14. #14 Re: sorting through some KR problems
    Jan 2009
    Tallahassee, FL
    I understand ya, I go WOT sometimes just to remember why I'm fixing it
    Sometimes meaning like only twice a week
    77 Morris Garage B
  1. A/c Problems
    By TripleZero in forum General Tech Discussion
    Last Post: 08-12-2010, 10:57 AM
  2. Used car problems.... Help
    By ChipSmithers in forum General Tech Discussion
    Last Post: 02-10-2010, 09:58 PM
  3. Problems with my 04 GP
    By 04gpking85 in forum 04+ Specifics
    Last Post: 10-17-2009, 02:15 PM
  4. 3 last problems
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 06:14 AM
  5. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
