Thread: PCM mounting
Results 1 to 6 of 6
  1. #1 PCM mounting
    Donating Users
    NY
    I just made me a sweet new open cone intact (thanks Nawarkk for the how to write up) and because I'm a cheap bastard I don't want to cut up the airbox for the pcm tray like he mentioned. Right now the pcm is just hanging out on the metal shelf and I've heard that people just zip tie it down and call it a day. Two questions though:
    1. What exactly am I tying it to? The shelf itself using a big ass ziptie?
    2. What would happen if I just left it sitting on the shelf with no zip or other tie down? It doesn't really look like it has any place to go.
  2. #2 Re: PCM mounting
    Outer Space
    Quote Originally Posted by grannyprix View Post
    I do this.. no issues so far.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: PCM mounting
    Jul 2010
    Outside ATL
    I have not looked at the write up about the intake, but depending on where your tubing is routed and such there are holes drilled in the metal in the engine bay where the old air box used to live. I just kind of used the existing holes and zipped tied it around like a circle. But, it doesnt have much room to move you are correct, i do concur with your observation. Although being the way i am--it got old looking and ugly after a while. Just make a tray out of sheet metal and mount it inside so it doesnt jiggle around. There are many options but those are two of the easiest.
  4. #4 Re: PCM mounting
    Donating Users
    NY
    Thanks to both of you. Jiggly PCM here I come.
  5. #5 Re: PCM mounting
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    mines been sitting there for almost 2 years not tied to anything, no issues at all so you should be fine
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  6. #6 Re: PCM mounting
    Exactly...and if you feel like it needs to be tied down...big ass zip ties FTW
  1. Mounting HID ballasts?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 07-24-2010, 06:39 PM
  2. Mounting Kit??????
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2008, 02:08 AM
  3. ZZP FMHE mounting
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 07:56 PM
  4. GPS Mounting
    By iflycessnas05 in forum General Tech Discussion
    Last Post: 06-26-2008, 08:36 PM
  5. ballast mounting
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-31-2008, 12:40 AM
