Thread: Car Starting issue...
Results 1 to 6 of 6
  1. #1 Car Starting issue...
    utah
    I had this happen before but cant remember what the problem was...Pretty much when I start the car it wont crank, I give it gas and it starts up...then i let off the gas and it bogs right down. The TCS light comes on and on my cluster the low battery light is on...I litterally just had the battery charged a week ago...could it be bad battery/alternator? If my memory serves correct the alternator was the culprit last time
  2. #2 Re: Car Starting issue...
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    sure could be ..seem like could be something hanging up the belt also, hard to crank and no charge from alt. let us kno wat u find
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Car Starting issue...POR FAVOR HELPO...
    utah
    so Day 2 of this...went to advance, got a new alternator and charged the battery...put back together, and now doing the same thing...I changed the Idle Air Controller yesterday and the car was driving great, but when I went to take the car out last night it just wouldnt turn over...Pretty much I turn the ignition and it chugs like normal then dies...chugs like normal then dies...I give it some gas and it starts up but if I take my foot off the gas it dies. If I leave my foot on the gas it starts up and runs...I had this happen before and cant remember what i did...any help would be MUCH appreciated!
  4. #4 Re: Car Starting issue...
    GTX Level Member cerick08GP's Avatar
    Un-plug the MAF sensor, and see if it runs “better”. If it does run better, it is most likey the MAF went bad. Maybe
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Car Starting issue...
    utah
    Ok...CRAZYNESS!!! So I sat there with my foot on the accelerator for like 15 seconds and blamo...car went back to working awesome. I drove it, then started it a few times and works like a charm everytime...Was it vapor locked maybe?
  6. #6 Re: Car Starting issue...
    Apr 2009
    mine did the same thing a lil while back, i thawt it was the maf..turned out to be the idle control sensor. b4 i found out i changed the maf, the crannk sensor.....idle control got changed and it hasnt never stalled like that again. thank god! =) good luck
  1. 2001 Grand Prix Starting Issue
    By Badley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 10:12 PM
  2. starting issues
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 12:18 PM
  3. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  4. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
  5. Starting issue
    By MuTaLiZeD in forum General Tech Discussion
    Last Post: 07-31-2009, 01:03 AM
