i know i went through that whole thing. its this part at the end
"The last important thing to note that Swash discovered is that you need to make sure your PCM is setup to know it has the performance shift available. Here are tips for checking that.
1) Calibration Data-->Transmission-->Shift Switch-->Shift_Switch_Type = set this to 1 (default is 0)
2) Calibration Data-->Transmission-->Shift Switch-->Discrete_Switch_Debounce_Time = 25 (currently yours is 200 (I believe this is the factory default))
it makes it seem like you have to change setting on your pcm am i right?
