Thread: Hissing after turning engine off
Results 1 to 4 of 4
  1. #1 Hissing after turning engine off
    SE Level Member yekimmrt's Avatar
    raleigh, nc
    I have a 2001 GTP Coupe with 110K, and was diagnosing a water pump problem the other day when I noticed after I cut the engine off, there was a hissing noise coming from the driver side/rear engine compartment for about 30 seconds. I duplicated it several times, played with the obvious vacuum hoses, but could not locate the source. There doesn't seem to be any performance problems that I can't attribute to my water pump going bad. I'm not too heavy on the car, learning as I go, does anybody have an idea where this is coming from? Is it a normal pressure release or should I be looking for a vacuum leak? Any ideas would be appreciated.
  2. #2 Re: Hissing after turning engine off
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    Mine makes this noise if I've had the AC on.
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  3. #3 Re: Hissing after turning engine off
    Completely normal. It's the AC.
  4. #4 Re: Hissing after turning engine off
    raleigh, nc
    Awesome. Thanks!
  1. weird hissing in dash...
    By 2000GTP in forum General Tech Discussion
    Last Post: 06-19-2012, 03:09 PM
  2. Vibration when turning right
    By amc401 in forum Brakes/Suspension/Chassis
    Last Post: 06-17-2010, 11:01 AM
  3. Cold Start Hissing
    By SuperSport in forum General Tech Discussion
    Last Post: 07-24-2009, 12:56 PM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
