Thread: Adding coolant
Results 1 to 6 of 6
  1. #1 Adding coolant
    SE Level Member pmanchin's Avatar
    Delmar, Maryland
    Hello, (again)
    This is my second post in 1 day and I kind of feel retarded. I recently replaced the water pump and am to the point where I just need to add coolant. Is there a specific way to go about it because I was told it's pressurized and there is a certain technique for the coolant to enter the engine. Everything you have to say is helpful.
    Thanks much,
    Patrick M.
  2. #2 Re: Adding coolant
    GTP Level Member Scimmia's Avatar
    QCA, IA
    We don't have a pressurized overflow, just the regular old school setup. Add coolant to the radiator until full, add to the overflow, and start bleeding the system, adding as necessary. Nothing fancy.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Adding coolant
    Delmar, Maryland
    So I fill up from the radiator cap, close then begin filling through the coolant over flow tank until level? And bleeding the system consists of?
  4. #4 Re: Adding coolant
    Delmar, Maryland
    Oh crap, you mean bleed the system at the thermostat?
  5. #5 Re: Adding coolant
    Charles City, IA
    Yes that is what he meant.
    SMGPFC Two Nipple General
  6. #6 Re: Adding coolant
    Delmar, Maryland
    Thanks so much for the help guys.
  1. Adding HUD and a DIC to your 97-03 GP
    By $03gp/gt$ in forum How To Write-Ups/Tech Tips
    Last Post: 10-12-2015, 07:25 PM
  2. adding a hud
    By 1LoudGrandPrix in forum Visual/Body Modifications
    Last Post: 08-17-2009, 09:07 PM
  3. Adding a glasspack...
    By mcvey in forum General Tech Discussion
    Last Post: 08-07-2009, 01:54 PM
  4. Adding HUD ??
    By aries83 in forum Visual/Body Modifications
    Last Post: 03-16-2009, 07:45 PM
  5. adding a supercharger
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2009, 07:22 PM
