Thread: which would be more worth the money
Results 1 to 13 of 13
  1. #1 which would be more worth the money
    SE Level Member chunk88's Avatar
    Jul 2010
    Richmond, IN
    i was just currious if anyone knows if it would be possible to take a gxp v8 and put it in a 2000 gtp shell and roughly what it would cost to do so....also which would be more worth the money, doing the swap or just building my L67
  2. #2 Re: which would be more worth the money
    Jersey
    build the L67, not alot of aftermarket with the 5.3
    16' wrx sti- stock
  3. #3 Re: which would be more worth the money
    Jan 2009
    Tallahassee, FL
    I think that it has been done a couple of times. For the money that it costs to do you can just build the L67 and be faster.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: which would be more worth the money
    Charles City, IA
    build up the l67, if you are going for big power tubo it.
    SMGPFC Two Nipple General
  5. #5 Re: which would be more worth the money
    Jul 2010
    Richmond, IN
    ok thanks guys...im gonna build the L67 but does anyone know what kind of power differences i could get from a turbo over a supercharger? also does anyone know of any sites other than 3800 performance, zzp, and pfyc that carry aftermarket parts for these motors?
  6. #6 Re: which would be more worth the money
    Jersey
    Quote Originally Posted by chunk88 View Post
    Intenseracing.com, wbodystore.com, tripleedgeperformance.com and vendors on here
    Well, if you can afford a turbo, go for it, it will make more power with less mods. Your going to be going through transmissions like you change underwear though, or you can get a built trans from Dave at triple edge.
    16' wrx sti- stock
  7. #7 Re: which would be more worth the money
    you'd still nuke your tranny's. you NEED the 1" chain for it to survive.
  8. #8 Re: which would be more worth the money
    AAND...no one makes the 1" chain anymore...and if it is getting sold by someone...it goes for a ton last I checked.
    Just wondering what is with all these LS4 swap questions lately...its dumb...no aftermarket support hardly for the LS4 unless your pockets go a bit deeper...I can make a L67 go faster than a bolt-ons LS4 for about a grand or less
  9. #9 Re: which would be more worth the money
    New York
    Sorry to hijack the thread but if the 1" chain is a goner does that mean that mean that a turbo, or really any kind of high hp build is a no go?
  10. #10 Re: which would be more worth the money
    No it just means the transmissions aren't as strong.
  11. #11 Re: which would be more worth the money
    New York
    Ah good, well sort of lol.
  12. #12 Re: which would be more worth the money
    Myself personally Id rather just buy a whole wrecked GXP and take the seats suspension brakes wheels engine and trans. To make it cost effective and then sell what ever body parts I could to recoup some of the cost. Ive seen wrecks going for around 5000 to 6500. If you dont think their is an aftermarket for them check out ls1tech.com and look in the ls4 section. Sure it isnt cheap though. Guys over their got the cam heads and intake swaps down. Head/cam/intake ls engine will make plenty of NA HP for what the trans can handle.
  13. #13 Re: which would be more worth the money
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    No...they don't. You call 300 WHP numbers? Gimme a break. And why would you take the transmission out of it and put it in a '97-'03 car. Last I checked you can't even do that because the GXP uses paddle shifters anyways...totally different internals. Plus...the LS4 sucks. It makes stupid amounts and heat and requires a damn crazy amount of tuning to go fast. But to quote you...I can't justify spending all that money when you can do it on a MUCH CHEAPER ROUTE.
  1. how to make your projectors worth the money for cheap...
    By BoostJunki3 in forum How To Write-Ups/Tech Tips
    Last Post: 04-22-2012, 10:35 PM
  2. more mod money :)
    By gtpinsc in forum Off Topic Discussion
    Last Post: 04-18-2010, 11:09 PM
  3. Is it worth the time and money?....
    By grandprixxx3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2010, 01:08 AM
  4. Need money asap.... F/s
    By pdrr98 in forum Introductions/Noob Questions
    Last Post: 07-03-2009, 12:31 AM
