Thread: PLEASE HELP!! car starts then dies
Results 1 to 4 of 4
  1. #1 PLEASE HELP!! car starts then dies
    GT Level Member jdmgtp's Avatar
    MI
    I was on my way to work driving down the freeway when my engine just died. It will start and run for about 3 seconds before dying again. It starts every time and dies every time. I tried giving it gas as its dying and it didnt even bog or miss or anything. It's almost like the computer is either turing off the ignition or the fuel or both. The only way to keep it running is to hold the gas down and bounce it off the rev limiter. I also tried holding the rpms at about 2000 rpms and when I feel it about to die I quickly turn the key off and back on again and it continues to run another 3 seconds until I turn the key off/ on again.
    I disconnected my maf to see if it would run and that did not help, same deal. I also swapped the two fuel pump relays, no luck. I scanned with my hptuners and see no codes or any sensor information out the ordinary. I tried running the fuel pump in high speed and that didnt help. All I can say is that I just fueled up about 20 miles before then and changed my trans fluid the day before. Also I'm not running any o2's.
    I'm completely stumped!!!!
  2. #2 Re: PLEASE HELP!! car starts then dies
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    have you tried bypassing resister for the fuel pump?
    My EX wifes other car is a broom.
  3. #3 Re: PLEASE HELP!! car starts then dies
    MI
    I'm going to try that right now,
  4. #4 Re: PLEASE HELP!! car starts then dies
    MI
    Ok, so that worked. Does autozone carry a new resister?
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. Car starts then dies
    By silver2000se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 06:33 PM
  3. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  4. starts and dies
    By betsgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 08:56 AM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
