Noise was gone. there is no play if I tilt the pulley but if I rotate it left to right there is about 1/2" atleast. Coupler?
Also so if the main O2 is bad will it cause the engien to run rough enough to trigger the other codes or shoudl I get a new crank sensor also?
Thanks!!
